In need of a drill bit http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4479 |
Author: | LanceK [ Wed Jan 11, 2006 9:47 am ] |
Post subject: | |
Im desperate need of a drill bit to drill two holes in my (already installed) neck block. I remember talking about this before and someone offered to lend me one. Its the type that drills as you pull, so I would drill two pilot holes then insert the bit from the inside of the guitar and then attached it to my drill from the out side, then pull as it turns, this will all me to counter sink the nuts for the two neck bolts. Thanks in advance for your help ![]() |
Author: | Steve Spodaryk [ Wed Jan 11, 2006 10:38 am ] |
Post subject: | |
Lance, I think what you're looking for is a "counterbore". I don't own one, but I recently looked them up - to do the same thing you're doing. There are several types, but the ones that looked most useful attached to a regular drill bit, something like a 5/16" drill with a 3/4" counterbore. Yukon mentioned that it's important to use the same drill size to get good results, so don't go with an undersized shank. http://www.mcmaster.com/ part # 3105A13 page # 2331 Steve |
Author: | David Collins [ Wed Jan 11, 2006 10:40 am ] |
Post subject: | |
I have a few old spade bits that I have ground out and sharpened the back side of for interior counterbores. It's a pretty simple tool to make. We had a more official tool for this up at Elderly's (mainly for endpin jacks in extra thick end blocks) with a removable blade, but I don't recall who it was made by. If you would like I could try to find one of my modified spade bits and send a photo, but it's really quite basic. Just choose the right spade bit for the counterbore size and grind a cutting edge in to the shaft end of the spade, leaving the center the size of the pilot hole. The ones I've made were 5 minute grinding jobs, and cut a remarkably clean hole. |
Author: | Mattia Valente [ Wed Jan 11, 2006 11:31 am ] |
Post subject: | |
IIRC you're looking for a 'reverse spotfacing' bit, MSC or similar carry it. Leaves you with a flat bottomed counterbored hole. I don't have one, have never used one, but this questions comes up often enough that I've remembered the answer. |
Author: | LanceK [ Wed Jan 11, 2006 11:39 am ] |
Post subject: | |
Larry Presnall! Found it in the archives! "Anyway Lance, if you need it I have a 5/8" reverse spot-facer I can lend you!" YES pretty please! |
Author: | L. Presnall [ Wed Jan 11, 2006 2:33 pm ] |
Post subject: | |
See you other post!! ![]() |
